you can use paint by face, using a material named Visible_col_area, then make a material schedule.
otherwise, you will have to deal with calculated values with shared parameters, but it will be hard to have only visible area.
good luck.
Julien "Au royaume des aveugles, les borgnes sont mal vus!"
P. DAC Follow me on Twitter @Jbenoit44 - Blog: http://aecuandme.wordpress.com/
This is a post I have been meaning to put up since the back end of last year, for some reason I put it on the back burner and then never came round to...
