...but please, if we're going to have to help you using photos of your screen taken with a potato, could you at least do us the honour of turning on the lights and rotating the image?
Thank you for the screenshot, we can now see that you are using Architectural columns (not structural) and even the briefest of searches on your part would have revealed that architectural columns merge materials with walls - insomuch, this visual behaviour is by design.
That is not to say such behaviour is ideal.
So you need to one or more of the following:
1. define different materials (if they are indeed different) in your walls and columns
2. disconnect the ends of your walls so that they do not touch the column (this may also be detail appropriate)
3. swap the architectural columns for structural columnes
I couldn't understand that term " behavior by design"
Im trying, in plan view, to make the column more visible among two walls. At the moment it looks to be joined together as one piece, I want it to pop...
