Building Coder: Retrieving Newly Created Element Ids
    An add-in will often need to retrieve the elements that it just created for further processing. Frequently, the Revit API method used to create them will return their element ids. Sometimes, that is not the case. Now this topic arose again in a couple of cases and brought some other aspects to mind Using the element lister Consecutive element ids Retrieving recently added elements AEC job openings in Munich and elsewhere...
