I have created a bolted chamber below slab drainage fitting which has multiple inlet connections (3 or 5) but only one outlet which is the main drain run which goes onward to the next manhole. The family works fine other than it does not pass the drainage system name to the outlet. I think i could get one connector to do this by linking the inlet to the outlet, but i have multiple inlets which all discharge to the same outlet. Is there any way i can get the same system type on all parts of pipe connected to the fitting?
Thanks
Thanks
