(a serious error has occured. it is strongly recommended that you use save as to save your work in a new file and continue in revit.) I have created a Facade using curtain wall when i try to edit it shows these error. can anyone please help me out because i couldnt update the whole model now.
a serious error reg
select the facade elements and go to create group, then go to save as > library > Group, then select and erase the elements that causes the problem, finally go to >insert>Load as Group and look for your group file and load it into your project, that way you will able to edit the facade elements as an individual file and reload it into your project to avoid that behavior, hope this could help, best regardsAndres Franco - Architect - BIM Coordinator
E.A Poe
did you already try to check your file to look if there are some problems?, go to Open> Audit, that may find the reason of your issue!Andres Franco - Architect - BIM Coordinator
E.A Poe
We are getting a strange group error in all of the groups in one of our files. This error pops us whenever we try to add any component to any group. We...March 1, 2016, 02:18 PM
Hi All,
I am splitting a design services model into its constituent parts for shop modelling.
I have isolated geometry through...October 4, 2018, 03:32 AM -
I am getting this message even though I can copy to clipboard the group (with it's details) form another project and paste it in the new one.
...February 14, 2017, 11:01 AM -
What is the official exit to not get this error? I go to 3d view thinking I will be out of editing mode and try to save but still get the error.
...February 12, 2014, 01:18 PM -
Hi guys,
I got an error when I try to save my project it says something like: Square foot by foot. (The translation from french :"Pieds...November 26, 2013, 05:32 PM
