Hi guys.. I'm having a problem with those damn reporting parameters, and I would appreciate any help.
So I'm creating a stepped footing family, and all I'm left to do now, is have a parameter that would show me the slope/angle of the steps. (To check if the angle complies with standards).
And first, I've created an angular dimension, linked it to 2 reference lines, and I kept getting the error "A reporting parameter can be used in a formula only if its dimension references are all to host elements in family" . I'm not quite sure how to interpret this.. but I tried different ways to get the angle to work.. using reference planes as reference, model lines, using the lines in the footing itself, etc.
So I said.. angle doesn't work.. I'll try the slope method, by dividing the height to the length. I made total step length and height as reporting parameters, and I gave it a try.. didn't work. They were referencing reference planes.. so I switch to reference lines, model lines, using the footing itself.. nothing works. I tried different kinds of combinations, but in the end, I could not manage to use any type of reporting parameter in any type of formula, or any type of situation, dimension, references, etc.
I can upload the family. It is in RAC 2012 Format.
