We have set up a local Revit Server and successful connected to the Central Revit Server. The local Revit Server Admin page connects to central server correctly. On a workstation, in Revit, when I first "Connect to Revit Server" it works correctly. When I browse to the "Revit Server", then "Revit Server Models" to try and open a project, I get an error, "The Revit server you are trying to access in not available due to a server or network failure" etc...
Additional info: When I go back into the Connect to Revit Server dialog it now say the server is not available. I've tried connecting by name and IP. In all cases the web interface for the Revit Server Admin is working correctly. If I switch from the Server Name to IP it successfully connects to the Server again, but still errors when I try and browse to a project.
I've set the firewall exceptions per this post: revitclinic.typepad.com/my_weblog/2010/11/revit-server-and-the-firewall-exception.html, and we've even turned the firewall off entirely.
Has anyone else experienced this and solved the problem?
