Hello,
I created a shared parameter for titleblocks named "Drawing Number" to place in all sheets. I also add the same shared parameter for the labels in section marks; first changing its category to door tags, created the shared parameter there, then changed its category back to section mark(As section marks are system families and do not read shared parameters, I did this trick to show shared parameters in section mark I managed it this way.)
Then in the .rvt file, I selected shared parameter and chose "views" and "sheets" in the project paramaters.
Anyway, my problem is, I want these section marks read the shared parameter value(Drawing Number) in the sheets. Now it is showing question mark insted of the drawing number parameter that I create.
I need to show both drawing and sheet number in the section marks. That’s why I don’t use drawing number as sheet number
Could anyone please help?
Thanks in advance.
Thanks in advance.
