Mirroring a sweep.
    Mirroring a sweep.
    Is there a way, without entering into the edit mode, to mirror an in-place sweep family without it flipping orientation on you?
    If you select the sweep you should have some properties that allow you to flip it and change the rotation. Image is from the family editor but I'm pretty sure it is the same in the project environment.
    chad
      Thanks.
      But was asking about 'outside' edit mode.
      That is, if you have 30 sweeps and you'd like to mirror them all at the same time. Is there a way to do this in one move, without mirroring or flipping 30 separate sweeps?
        Are you in a project or family?
        For an in-place family in a project you can tie the Flip & Angle to a Family Parameter (which exists in the project), then modify it that way. You will need to edit the in-place family once to make the associations, but otherwise it will be pretty simple.
        Your other option would be to start digging through Dynamo.
        chad
