I need to span wood studs with window screen (because I work on high end projects like that), and thought I would use a curtain wall with mullions for the studs and thin curtain panels in front of the mullions as the screen. The only hangup is the screen should be one roll across the wall and studs, but each panel joint is visible. Is there a trick beyond the linework tool to make the curtain panels look like a single panel in front of the mullions?
high end curtain wall composition (not)
Originally posted by lost again again View PostI need to span wood studs with window screen (because I work on high end projects like that), and thought I would use a curtain wall with mullions for the studs and thin curtain panels in front of the mullions as the screen. The only hangup is the screen should be one roll across the wall and studs, but each panel joint is visible. Is there a trick beyond the linework tool to make the curtain panels look like a single panel in front of the mullions?I'm retired, if you don't like it, go around!
David: Thank you for the suggestion. I want the studs behind the screen, so that inside you see studs and outside you see one sheet of screen. As the length of screen increases, so does the number of studs, which is why I followed my first guess of curtain wall. I'm not immediately sure of how to do that with a generic family.
Originally posted by lost again again View PostOK just one more question Dave if you don't mind - how do you change the mullion profile to not cross the curtain wall placement line? I changed the rectangular mullion's "offset" parameter to 1/8" then to 12", but neither of these settings is removing the curtain panel joints in elevation.
if you'd like a project with these curtain walls just PM me
oh, and here's a plan viewLast edited by Dave Jones; January 26, 2018, 09:22 PM.I'm retired, if you don't like it, go around!
Thanks for the confirmation, Dave. Your example looks just like I imagined. I will keep it in mind - this project, like every project, is sure to become more complicated and replacing my single curtain wall (with adjusted linework at elevations) with two adjacent curtain walls just may be justified before I'm done...
Originally posted by lost again again View PostThanks for the confirmation, Dave. Your example looks just like I imagined. I will keep it in mind - this project, like every project, is sure to become more complicated and replacing my single curtain wall (with adjusted linework at elevations) with two adjacent curtain walls just may be justified before I'm done...I'm retired, if you don't like it, go around!
Originally posted by lost again again View PostDavid: Thank you for the suggestion. I want the studs behind the screen, so that inside you see studs and outside you see one sheet of screen. As the length of screen increases, so does the number of studs, which is why I followed my first guess of curtain wall. I'm not immediately sure of how to do that with a generic family.
It is possible, even easy once you get the hang of it, to make families that add pieces as the family gets longer. You should be able to find examples of things like ladders that add rungs as it gets taller.My ID was stolen. Now I'm only called Dav
Normally in curtain walls panels are situated in middle of mullions (as seen in plan). If I need to place mullion in back face of panel, how to proceed...August 25, 2014, 06:25 PM
in revit as default we can only make curtain walls with orthogonal horizontal and vertical mullions... now how can i make a disordered curtain wall. with...July 29, 2013, 10:02 PM
Hello,
I have a standard curtain wall. On the upperside of a transom there is a continuous small L-profile (between the 2 mullions). And...May 30, 2017, 11:24 PM -
Hello,I have to model a curtain wall in a project (see underneath link). it's a segmented curtain wall. The nods in the layout are not everythere the...December 23, 2016, 01:41 PM
I am working on my first project in Revit. I am renovating a car dealership. I modeled the existing shell, useing phase filters to differentiate between...February 13, 2015, 12:51 PM
