I am very new to Dynamo. This is my first kick at the can and I am trying to use dynamo to eliminate some user inputs in our structural projects. I have a custom parameter "Tag Prefix" attached to multiple categories, including structural framing, and our structural framing tag references the "Tag Prefix""Type Name" to give us a tag that reads (N)W12x26. What I am trying to accomplish is to set the "Tag Prefix" parameter based on the "Phase Created". I have attached my first try. Obviously I have something wrong since it only sets (E) to all structural framing.
Setting Revit Parameter by "Phase Created"
This topic is closed.
Doesn't look like your attachment made it.
Without seeing the graph, it sounds like a lacing issue. What's a List | The Dynamo Primer
note: Thread closed as a duplicateLast edited by cellophane; January 26, 2018, 06:26 PM.
I am very new to Dynamo. This is my first kick at the can and I am trying to use dynamo to eliminate some user inputs in our structural projects. I have...
Channel: Dynamo BIM
January 26, 2018, 04:00 PM -
I have a generic annotation tag attached when I change the category to a structural framing tag I lose the snap points is there a way to keep the snap...April 5, 2021, 03:17 PM
I have a custom joist family that I created and set to the Category "Structural Framing". When I try to tag this family in my project with the...January 14, 2013, 04:05 PM
Hi, this is a very newbie question but what tag do I use when tagging a plate girder to have its dimensions showing. I have tried lots of them but cant...
August 25, 2016, 08:46 AM -
Hello All
as you will see in the attached pic, i was able to modify the system families for the framing elevation tag, however the problem...-
Channel: Structure - Family Creation
October 11, 2017, 06:33 PM -
