Place Views on sheets - lots of
    I have a project I'm doing for a multi-story tower block, I have to say like 20 floors, 1 view for each floor, times about 8 1 for each discipline.
    thing is I have to get all these views onto separate sheets :banghead:
    is there any quick way of doing so?
    Cheers
    Don't have a script lying around, but I guess Dynamo is your best bet (will be looking at this myself for a project in the near future). Might take some time creating the script, but it beats making 160 sheets, filling in the data and placing a view on each of them.
      Yep!
      This should get you started;
      I think this is a common desire for many users of dynamo is to automate views and sheet creation. There are many posts and requests on this forum for it… I found useful information is spread across the net. As I expect there are many who have created useful graphs, and many new users interested, the intent for this post is simply to share what I found useful in one place. View.Sheets.ByNameNumberTitleBlocksAndViews does not have any control for placement. After lots of trial and searching,...
      Or try this dynamo script to begin with (You will have to modify it to work with your own methods of numbering etc but it should give you an idea how to do it);
        Originally posted by josephpeel View Post
        Yep!
        Cheers
        have you used it before, I have not really used dynamo much, what do the red boxes mean its saying something like custom node.
          Go to packages and search for Clockwork and Archi-lab. Download them and it should work. If you are still missing any then search for the node name to see what package they are in, but I mostly only use those two.
          Thats kind of the thing with Dynamo.. You cant really expect to just download a script and run it, theres always some adjustment needed to your own setup and parameters etc. But well worth getting to grips with.
          Basically anything that revit should be able to do but wont let you.. can be done with Dynamo.
            you couldnt do a little video could you on how to use this
              Not a video, but here's the best place to start with Dynamo:
              About | The Dynamo Primer
              To further expand on what Joseph said: Dynamo is like Revit:
              You can't expect to just install it and crank out a 10-story building that afternoon.
              You have to invest some time and learn what it does and how it works.
              Dave Plumb
              BWBR Architects; St Paul, MN
                I'm trying not to sound like an advertisement, but I've used the Sheet Duplicator add-in in 2017 with success.
                Although if I could work it in to learn Dynamo I would.
                • Dynamo Revit
                  I've recently been looking into different ways to speed up my Revit workflow, such as scheduling and using shared parameters. I was told to look into...
                  September 25, 2018, 09:48 AM
                • Creating Sheets
                  I'm stuck on getting Dynamo to create sheets. I can read the data from the spreadsheet but I can't get the sheets to actually create... I've tried the...
                  December 8, 2015, 06:04 PM
                • Placing Views on Sheets
                  Stupid question:
                  I'm trying to place some dependent views onto sheets. I can collect the views, the sheets, the viewport location from the reference...
                  June 26, 2018, 02:02 PM
                • Quickly setting up projects? Copy Architect Views?
                  Hi everyone. Right now it takes us forever to set up a new project. We have a template made (and are working to improve it), but so much time is wasted...
                  February 27, 2017, 09:34 PM
                • How to place Views on Sheets defined by location
                  In this script I want to create Views from Levels, Sheets from Excel and placing the Views on the created Sheets, all at the same time using ONE script....
                  November 20, 2019, 07:48 PM
