(double posted over at Autodesk Forums)
I'm having a weird issue with Navisworks 2018. This is a consistent problem and I cannot think of what might be happening. If you refer to the screenshot, you'll notice that even though I have sectioning enabled, there are still objects beyond the cut plane that are visible, but they are very faint, like a ghosted transparent model. Is this a bug? Or is there some setting or checkbox I'm overlooking? It's very distracting and takes away from the entire reason to section a model. All software is up to date.
Thanks in advance!
-TZ
Thanks in advance!
-TZ
