I'm building a "super cabinet" family that is made fairly exact to how cabinets are actually built. I have my adjustable shelf as a 3D extrusion inside the cabinet, and in the front elevation I have dashed symbolic lines aligned/locked to the shelf model geometry. The model geometry and symbolic lines are all tied to a Yes/No parameter to control whether or not the cabinet has a shelf inside. Works great in a project.
However I also need the text "ADJ." just above those dashed symbolic lines that will show up in a casework elevation view. I need to be able to align/lock the text to ref planes so that it will adjust based on the shelf's position, and I also need the text to turn on/off following my Yes/No parameter for the shelf.
Is any of this possible with anything other than model text? I really, really want to avoid model text if at all possible.
