I am looking for resolution to an issue i'm having. I have tried to bring a family in from manufacturer website and i am getting the following error when trying to load. "The shared parameter "eb8052e8-d47c-4de2-992a-5b7f89756df4" cannot be added with name "Product Page URL" and type "Text" because it conflicts with the existing name "Product Page URL" and type "URL"." Can any one help out with this issue. I am using Revit 2018
Shared Parameter Conflict
You can make URL shared parameters too. I think in this case its just very unlucky that there is already a parameter with the same GUID. Or both parameters come from the same manufacturers families and they changed the shared parameter type from Text to URL at some point.. (They would have had to edit this in their shared parameter file).
The solution is; Dont load crap families that you find on the internet...."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Conflicting shared parameters
Originally posted by wildirish317 View PostIf you can open the family by itself in Revit, do so, and delete the offending parameter. Then load it into your project.
Your project has a shared parameter "Product Page URL" that has a URL type, and your family has a shared parameter of the same name, but different type.
I'm also trying to get a family in our template and I et the following error:
The shared parameter "00000000-0000-0000-0000-000000000000" cannot be added with name "00_isq_hoogte_min_2" and type "Length" because it conflicts with the existing name "REX.Content.Identity.RebarHooks" and type "Text".
Strange thing is that I can't find the "00_isq_hoogte_min_2" parameter in the family nor can I find the "REX.Content.Identity.RebarHooks" in our template. Even if I'd delete all parameters from the family it still gives the error. Any idea's?
Regards Rien
Sometimes there is a conflict between parameters in families, and project parameters. Maybe check the project parameters to see if there is one with that name.
If not, the problem is likely that there is a parameter with a different "Name", but with a duplicate "GUID". This is especially likely since the GUID listed above is all zeros. There's probably more than one lame family creator, or buggy addin and they both inserted zeros.
Hi
I'm trying to make a annotation for a structural foundation, I've drawn a couple of filled regions which turn on/off depending on a number...-
Channel: Structure - Family Creation
May 7, 2018, 01:07 PM -
Hello,
I created a shared parameter for titleblocks named "Drawing Number" to place in all sheets. I also add the same shared...February 3, 2018, 06:29 AM -
So, we got this nice new feature in 2015 so we can reorder our parameters and get out families nice and neat and organized.
But it doesn't seem...-
January 12, 2015, 03:46 PM -
I'm in Revit 2017.2
I have a shared parameter named Voltage_(company name)
I have been re associating my connectors with my...-
Channel: MEP - Family Creation
July 13, 2017, 03:15 PM -
Has anyone seen this warning?
""The shared parameter 'ee35ad84-b029-481a-b600-c9e17da63d7d' cannot be added with name 'Material'...-
Channel: Tutorials, Tips & Tricks
November 6, 2014, 09:20 PM -
