Changing offset value
    I'm constantly using offset in my projects but I bounce back and forth on how far I'm offsetting objects. I currently have a key on my keyboard macroed to the offset function and what I would really like is if I could just hit that macro and then have it automatically require me to type in the offset value. I think this would save me time in the end. So for an example say I want to offset something 1' I'd want to "hit "m4", type in 1, hit enter" and then offset away. If I wanted to change it I'd just want to "hit "m4", type in 2, hit enter" As it is now, if I hit m4 I have to mouse over to the offset amount and click and then change it.
    It's not going to save a ton of time but there should be some way I can set up a macro or something for this to work. Any ideas?
    Just found a thread from a few months ago, and in that thread nobody had any ideas how to make it work. I really think there should be some way to make the program do this with via macro management... Unfortunately I have very little knowledge of macro management. If I don't hear anything back on there then I'm going to dive into it myself and see if I can figure out a way to do it in the macro manager.
      Agree, the offset can be a pain especially with inputting. Dont do it carefully every time and you might not input the right amount. Needs to be a bigger window. An immediate shortcut would be fun.
        An Immediate shortcut is exactly what I'm looking for. There's gotta be a way to set up a macro to automatically "click" into the offset area upon clicking the offset button. Can't imagine a program as powerful as revit can't be customized like that.
        • Offset taper? or Offset transition?
          How do you go about drawing an offset taper/transition my engineer wants me taper down straight after coming off an AHU so that we dont have to put any...
          January 14, 2014, 07:10 PM
        • Offset Sink Trap
          I need an offset trap for an ADA sink with exposed piping and don't have a clue how to make one or frankly what one is, other than a trap that is offset...
          May 16, 2012, 04:08 PM
        • Positive Negative offset
          I want to create a family that has geometry that can be offset from a centerline with a positive or negative value. Essentially, moving an object to the...
          December 14, 2010, 05:16 PM
        • Forumla to offset
          Hi All,
          I am trying to create a parameter that can control an offset from a line, the issue is I want this offset to work with both positive...
          November 26, 2015, 12:19 AM
        • Scheduling the Offset constraint
          I've searched profusely, but most posts center around actually creating a parameter from the Offset constraint which has all of the integrity of a built-in...
          June 9, 2011, 09:50 PM
