Please see attached, I am trying to apply the custom wall sweep on the top of a ramp wall, since it is angled, is there a certain method for doing this? Any advice greatly appreciated (see red arrow on right of image) THANKS A TON IN ADVANCE !!! madeline:banghead:
Wall Sweep on angled wall
I would probably go with a generic model for all of the elements.Company Website: www.deurloobm.nl
Originally posted by maddyjdelaney View PostPlease see attached, I am trying to apply the custom wall sweep on the top of a ramp wall, since it is angled, is there a certain method for doing this? Any advice greatly appreciated (see red arrow on right of image) THANKS A TON IN ADVANCE !!! madeline:banghead:I'm retired, if you don't like it, go around!
to do what snuffy is suggesting you need to use the in-place component, the create a sweep using the same profile and use the pick line tool to select the edges of your site wall.Scott D. Brown, AIA | Senior Project Manager | Beck Group
All,
This one is throwing me for a loop, I have a simple wall with a mitered corner and a wall sweep on the top and bottom. Neither wall...May 25, 2017, 09:35 PM -
I have a long thick wall with a few openings on it. I am trying to get the sweep to return inside the openings without breaking up the wall. I have tried...April 27, 2018, 09:04 PM
Hello, as you see in the attached image I want to make a wall sweep that runs twice around the head of the wall. For now, I can turn it only once ......February 24, 2012, 01:04 PM
I was wondering how to create a wall sweep on a gable-end wall? I would like to show a trim board at the top of the gable-end wall that follows the...August 3, 2016, 03:59 PM
I am not sure why this sometimes happens with wall sweeps. There are like, 6 nodes. I just want two so I can drag either end and have it stretch to to...December 11, 2017, 05:59 PM
