has anybody else experienced wall joins "breaking" when editing unrelated parts of a model? We've experienced it in several projects now on several different stations, so I'm 95% sure that we can rule out a local issue with a specific model or workstation.
2018 Wall Joins "Breaking"
I've only ever seen that when there have been complexities in the joining of a wall that spans multiple floor levels joined to one or more walls perhaps that is/are only at one level - corners can get too complex then for Revit and need breaking into simpler pieces - or as a last resort disabling the automatic cleanup of the corner.
typically walls join correctly if they share the same base and top constraints, if one goes only one story and another goes three you will see this behavior.Scott D. Brown, AIA | Senior Project Manager | Beck Group
I have a series of projects that I cannot get to work easily in regards to getting the walls to join correctly.
I have attached a typical...February 10, 2012, 04:57 PM -
I have got a quick question being that the entire course of this project i have had countless issues with wall joins and i am back on it for an addendum....February 12, 2013, 01:23 PM
Hi all,
I am facing some troubles in wrapping the compound walls.
Firstly, here are the components of the compound wall:
...February 24, 2018, 12:27 PM -
I'm trying to disconnect joined walls. I would like my model to reflect the segmented way of building shown in the picture. The screenshot shows how far...May 21, 2014, 02:25 PM
I've recently decided to go full-on with Revit, rather than dipping my toe in out of it, and I'm enjoying making some (slow) progress. But I keep getting...April 6, 2018, 09:28 PM
