Revit2017.
the panel is a system panel, glass.
Whne I trid to add a grd line, the error popped up, impedes me to continue the operation.
That magenta is the DWG behind, I have to spli tht alast panel and then insert a couple of window
It is a new limit/error to me.
It never happened before. I do not understand why.
A workaround should be create a panel with two window in the upper side that requires some time
instead of just placing windows.
Any suggestions or solutions?
