ı just started using revit and wanted to know how can we draw plumbing pipes or hvac ducts in a building? or we draw lines and assign them cross section geometry? if so how? ı saw no command or button to draw pipes.
how to draw pipes or mechanical ducts
There's a whole section of the Ribbon devoted to MEP. Do you have a Tab called "Systems"?
If not, next question is what version of Revit are you using?
Earlier versions did have a whole separate install for the MEP part, but those are probably completely obsolete by now.
Assuming you have a recent version of Revit, you may need to turn on the Systems tab.
Go into the "Big R" (2017 & older) or the "File" menu (2018). There's and "Options" button in the lower right.
In the Options, go to User Interface & on there you'll see checkboxes to turn on the Ribbon for each discipline.Dave Plumb
BWBR Architects; St Paul, MN
Hello all, how to remove dashed lines of pipe which is located under the pipe in floor plan?
best regards
Channel: MEP - General
January 25, 2014, 10:25 AM -
Hello
I am new to the Revit world. We are currently using Revit 2012.
When you first open Revit, at the top you have the...-
November 17, 2011, 02:15 PM -
Hey
I am wondering, if there is a way that revit can calculate the size of the ducts depending on the airflow, velocity and the type of...-
August 10, 2012, 07:08 PM -
I'm new to Revit MEP and am sure this is a stupid question, but I'm wondering if Revit MEP will do water pipe sizing calculations. There are all sorts...
December 12, 2011, 06:26 PM -
If u are drawing a santi pipe and u need to have a rise going to another floor and a drop going to a lower floor is there a quick way to draw this or...September 19, 2014, 08:09 PM
Monumetric Footer In-screen
