Inside walk line.
    Inside walk line.
    Hi.
    I have U shaped stairs in Revit and I have question about them.
    There is a parameter Inside Walk Line Offset which I set to 40 and Minimum Width on Inside Walk Line (read only) that shows 25,03 but in model the distance is shorter than 25. How can I control that?
    Is your stair a winder type? I thought that setting applies to those only? Here's a help section on the features.
