We've got a Sheet with 3 Views on it.
Only one has Depth Cueing turned on, but all 3 Views act as if they had it on.
The View on the bottom uses Depth Cueing, while the two on the top have it off.
The upper floors on both of the top Views should be dark.
And they are dark on Revit. the problem is that the Depth Cueing gets applied to the other Views when the PDF is created.
I've checked 3 different PDF printers (Cute, PDF Creator, Bluebeam) and they all do the same.
BTW, the Views are off the sheet because my first thought was that this happened because they overlapped. So I separated them.
Sheet 513.pdf
Sheet 513.pdf
