Building Coder: Pipe Fitting K Factor, Archi+Lab and Installer
    Two recent Revit MEP related cases brought up some new information on the pipe K factor table and custom calculations for pipe fittings, the Forge DevCon class recordings are now available, and I discovered Konrad Sobon's wonderful archi+lab Revit API blog, which helps resolve an installation and setup issue Pipe K factor table Custom K factor calculation for pipe fittings Dynamo code to change loss coefficient Forge DevCon 2017 class recordings Archi+Lab Revit add-in installer and buttons...
