We have previously used Model Lines to define horizontal banding on walls. This usually leads to unhappiness.
We are now testing using a Curtain Wall.
* Curtain Panel is defined to be our desired Basic Wall type,
* Horizontal Grid Spacing is set to the desired banding height
This seems to work, allowing us to Cut in Curtain Wall Windows objects successfully.
What is problematic is standard Door and Window items.
But this should not be an issue as we will use our Curtain Wall doors and Windows.
Are there other problems we might encounter with this curtain wall method?
Is this a good technique to use?
Thanking you in advance.
