roof not visible in enlarged plan view but visible in all other views 2017
    i have a roof that after making some changes to the footprint said roof it disappeared in only one view (enlarged floor plan. I am able to see and select it in 3D, overall floor plan and other views. for some reason it does not appear to be there or it appears to be transparent in this particular view. i have checked the view template, VG overrides and those settings seem to be the same as the other views. not sure where to go from here.
    Did you check the view range?
      I was comparing the view range bottom & view depth. in the good view they were both set to unlimited. in the bad view they were both set to associated level. the strange thing is, is that that was the same before this problem occurred. now my problem is that if I set the bad view to unlimited it shows the ground floor below in the bad view (enlarged plan). which I do not want to show.
        Try using an Underlay, set to look up--then use Linework Tool, then turn off Underlay, and linework will remain, and move with roof it it gets edited, etc.
        Cliff B. Collins
        Registered Architect
        Autodesk Expert Elite
