Visibility question - can't see the 3d models other half
    how come i can't see the other half of my model.
    Thanks.
    Looks like Far Clip Active and Far Clip Offset values need to be examined. Active determines if Revit should stop showing the model at a distance and the offset decides how far that distance is.
    • Offset taper? or Offset transition?
      How do you go about drawing an offset taper/transition my engineer wants me taper down straight after coming off an AHU so that we dont have to put any...
      January 14, 2014, 07:10 PM
    • Offset Sink Trap
      I need an offset trap for an ADA sink with exposed piping and don't have a clue how to make one or frankly what one is, other than a trap that is offset...
      May 16, 2012, 04:08 PM
    • Changing offset value
      I'm constantly using offset in my projects but I bounce back and forth on how far I'm offsetting objects. I currently have a key on my keyboard macroed...
      January 9, 2018, 06:28 PM
    • Boolean Expression Error
      Good morning!
      I have a new problem with formulas and visibility parameters.
      I’m looking to make a generic mechanical Face Based...
      March 12, 2014, 10:38 AM
    • Forumla to offset
      Hi All,
      I am trying to create a parameter that can control an offset from a line, the issue is I want this offset to work with both positive...
      November 26, 2015, 12:19 AM
