Should I leave Object Style as default? Is that a good way to proceed?
vague question, but I love to use object styles and sub categories to control the vast majority of materials for that category. IE your windows for example, you may have a dozen diff. types of windows all with material parameters set to <by category> So assuming your families are created properly, if you want all your windows to have a white painted frame and clear glass, you would set those materials under object styles and it would apply to all your families without you having to manually edit the type properties for each type. Then you only need to edit any that are unique.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Object Styles don't equate to Materials that you need to show on schedules. OS does give your "(sub)categories" a line weight & a "rendering material" that is not traceable in a component schedule. I do create Materials with Names of abbrev. that I want called out in schedules thou instead of text parameters. Revit w/o Materiality is like the Patriots having Coach Belichick but w/o Tom Brady.Last edited by cftrevizo; December 7, 2017, 08:34 PM.
Where's the best place to store Object Styles, Line and Fill Patterns, and Materials and Appearance Assets -- in the RTE or the RFAs?
RTE...June 16, 2020, 03:09 PM -
Is there anyway to merge materials? I have a few families from manufacturers and the materials are named in goofy ways, usually with the mfr. name and...December 13, 2012, 05:18 PM
Do you check "Composite Object Clashing" and in which situations?
Walls made of several layers and windows (composed of frame and pane)...-
Channel: Coordination Tools
August 1, 2014, 08:39 AM -
Hi I'm pretty new to Revit. I just learnt how to create new subcategories and the line colours, line pattern and line weights will work but when I set...
Channel: Out There
August 30, 2016, 11:30 AM -
hi again
the Revit STR Temp in my office has every single line in " object Style" set to 3.
does anyone know if I can find...-
November 30, 2016, 09:32 PM -
