I have a site file with a building file linked into it. Revit will not allow me to publish coordinates from the building file to the site file. Both files are workshared, Revit 2018.
I can set up the shared site in the site model, but when I try to SWC, I get an error message that says "Link Cannot be Saved: You cannot save the link BUILDING.rvt because it has changes in more than just shared coordinates, which can invalidate local files owned by you." The message actually pops up twice during SWC, I assume each time it is trying to save the local site file.
I have done some research on this issue. There are no other links in either file (DWG or rvt), and the linked building has also been SWC before starting this process.
The trouble seems to be something in the building file because if I create a new test building model, I can link it into the site and publish coordinates just fine. I have also created a new site file for testing and the building model behaves the same way, so it's not the site model. Does anyone have any clues about what might be causing this and how to fix it?
