no plot lines
    no plot lines
    Is there any way to create a no plot line in Revit 2018?
    Quick answer, No.
    Revit is WYSIWYG. If you see it on the screen, it'll plot.
    That said, there are a couple of exceptions and an Add-In that could help.
    The exceptions are Reference Planes and View references (Elevations & Sections) that are not on a Sheet. But I doubt that's what you're asking for.
    To quote Chad in this thread:
    There is an Add-in that might help
    Dave Plumb
    BWBR Architects; St Paul, MN
      You can make a linestyle that you turn off with a view template for example in the view you want to print.
      Revit is 'what you see is what you get', so a none printable line would be invisible in the view you are printing.
      [edit]
      LOL, looks like great minds think allike
        Make the no-plot line plotted as a white line. You'll never see it on white paper
          But then you won't see them in Revit either, right?
            Commence color debate in 3... 2... 1...
            Tony Perez @Twitter
            Senior BIM Specialist
            Salas O'Brien
              I use a very very light line that plots but isn't really noticeable if it's small. I only use for special cases like needing to dimension to something that you can't normally. Otherwise, that's what additional views are for, ie "working" views.
              Fred Blome
              Residential Architect
                Go bold. Draw on a hot pink
                  Why, whats wrong with that ??
                  Think I did that once in AUtoCAD for a co-worker during April fools or something.
                    I did that to a grad recently. Completely freaked him out :laugh:
