Building Coder: Automatic Wall Creation
    Alexander Ignatovich shares an exceedingly elegant solution for automatic wall creation, illustrating a number of important concepts and implementing the following functionality very succinctly indeed Retrieve all the cube family instances Retrieve their height parameter value Retrieve their solids making use of the .NET yield operator Extract their horizontal outline contours using an ExtrusionAnalyzer Create walls along each contour curve segment Place a door family instance at the midpoint of each wall...
