Cut a Nested Family (used to create an array) with a Void
You're welcome! It was an interesting puzzle because I was sure I'd seen it done before.
i think this is EXACTLY what i needed. Can't thank you enough!!!!!! I've been racking my brain all day.
Hmm - looks like you need a face based void family to cut loaded families. You will need the third family, since trying to cut the array in the family where it is arrayed gets the "changes to groups are only allowed in group edit mode error" So you'll need 4 families.
slat>slat_array>Vented Slat
face_void>Vented Slat
Edit: here's a draft family (2017)Attached FilesLast edited by jmk; November 29, 2017, 11:56 PM.
I haven't tried nesting it a third time. I tried just nesting the single slat, array it, and then have a void cut the curved edges.
Are you arraying the curved edge slat family multiple times, or are you arraying the ridges to make the curved slat to get different sizes? Does the radius/size of the curved area vary?
The first should be doable by arraying the element with the void (may need to do it in a second family). For the latter I don't think voids will cut an array, and if they do I suspect it would be unstable when the dimensions change. I'd try using 3 families - slat, nested into slat_array, nested into Vented Slat where it is cut by the void.
I apologize if this topic has been been addressed before, or if there's a definitive answer on the subject BUT....
I'm creating a custom "Vented wood slat" family that has curved edges and will be many different sizes throughout the project. I would like to use a nested "slat" family, and then array it according to the size that will be eventually used. However, because of the curved edges on all four sides, I was thinking i would have a void, to cut that nested family, around the corners. Can I do this?
I'm attaching a photo of what i'm trying to achieve.
Thank you in advance!!!Tags: None
Hi Revit Battle'ers. Can you offer some wise words?
PROBLEM: How to make a fraction of an arrayed item?
EXAMPLE: Arrayed item=100mm...October 9, 2016, 07:40 PM -
Hi all,
I am going to build a family for flangs. I have a couple questions to point me in the right direction.
Different sizes flangs...-
Channel: MEP - Family Creation
September 4, 2018, 10:25 AM -
Hello there,
I am working on a parametric portal frame that has a unique web. The web is corrugated and is a nested family because it uses...-
Channel: Architecture - Family Creation
January 15, 2018, 08:36 AM -
Voids and solids interact in a specific order according to when each are created. I wrote another post to describe this in the past (July 2006). When...
Channel: Blog Feeds
August 23, 2011, 03:07 PM -
Hello Everyone,
I have created this sash family with parametric grille/muntin not sure what the correct term is attached is a screen shot...June 25, 2021, 05:43 PM
Monumetric Footer In-screen
