ok, have selected basic wall exterior-wood Shingle on Wood stud. go to Edit type, go to Edit structure, go to finish, click wood shakes, can't figure out hoe to change oob 6" dimension to 10" anyone know how???? don't want to change from model to drafting
revit 16 wood shingle(exposed ht.) on elevation oobox (6") want (10')
Originally posted by duende123 View Postyou have to reimport the .pat
then you can change the scale factor
Getting to the small things that matter with the Revit 2018.2 update - Revit Official Blog
(item #3)Dave Plumb
BWBR Architects; St Paul, MN
thank you duende 123, and thank you DaveP, your replies are very helpful. First of all my initial question was misstated by me. I meant to ask about shakes not shingles. Shingles which I can use are easy to deal with. I may go back to the shakes pattern once more and try duende123 suggestion just for drill, and thank you DaveP, I will update soon as per your suggestion.
Is there a way to change the formatting of the "View Scale" parameter in a view title? The formatting option is grayed out and not selectable...May 28, 2015, 02:01 PM
Is there any way for a view to have a 2:1 (or any other "larger than life" for that matter) view scale?
Revit won't let me enter...March 20, 2012, 05:44 PM -
I am learning Revit for the first time. I have been using a book, Autodesk Revit Architecture No Experience Required. Through the third chapter it tells...January 6, 2014, 12:00 AM
We have recently started using Hatch 22 for Revit 2017. Is there a way to make the newly created hatch to resize at different scales? They were created...February 7, 2018, 09:22 PM
Hey guys
I've scaled a 1:100 view to 1:200 & the elevation tags become way too big for this new view.
Is there some way to scale the tags...-
February 23, 2012, 05:13 AM -
