How do i create a 'demo hatch?'
    Hey everyone I am trying to create a custom filled region (transparent ) to use to show something being demoed. Please does anyone know of a simple way to do this?? I tried making a repeating pattern, but it wasn't dense enough, and took forever. I am trying to make the dashes offset from each other as well. Any detailed explanation would greatly help !!!! I attached an image to show what i am trying to re-create. THANK YOU TONS IN ADVANCE !!!!:banghead:
    First question is: Why are you using a Filled Region to show demo?
    The "Revit" way to do demo is to set up graphics overrides in your Phases and assign a material/pattern there.
Name:	Phase Graphics.PNG
    Then, when you demo an element, it picks up the graphics automatically
    Dave Plumb
    BWBR Architects; St Paul, MN
      [ATTACH=CONFIG]32214[/ATTACH]
      I had to create one for grid ceilings as I couldn't fine a method of turning the 2x4 grid pattern into dashed lines.
      Bettisworth North
        OK, I'll give you Ceilings.
        We've got a Ceiling Type explicitly for 2x4 (and another for 2x2) demo'd ceilings that uses a dashed line for the runners
        OP didn't say anything about Ceilings, though.
        Dave Plumb
          Sorry Dave, that is correct. Then, how do i create a new pattern so all of the demo elements can show as 45degree off-set dashes !? It is not a choice in my drop-down menu,
            See this thread:
            Dave Plumb
              Install pyRevit to create the pattern you want, or see attached. I'd create a Filter & apply that model pattern.
                cftrevizo - I am not sure that is the pattern i want, or is there any way you can show me an image of what those look like? thank you so much ! i'm looking for a pattern that looks like this:
                  perhaps:
                  ; Written by HatchKitCS
                  ; HatchKitCS (c)1990-2017 Cadro Pty Ltd
                  ; www.hatchkit.com.au
                  ;-Date : 25/11/2017
                  ;-Time : 7:54:25 PM
                  ;-HatchKitCS Version : 3.1.10.2730
                  ;-HatchKitCS Output Filetype : Revit with HatchKit Add-In
                  ;%VERSION=3.0
                  ;%UNITS=INCH
                  *DASHES,for demo
                  ;%TYPE=MODEL
                  0,0,0,5,-2.5,2.5,-7.5
                  hth,
                    hugha- is there a way to create that pattern script within Revit itself without installing this HatckKitCS add on!? I just worry about third party add-ons, as i work for a company, not myself. Forgot to mention, I am a newbie. thanks again for any detailed explanation about how to create a custom pattern within Revit.
