Hi all,
I know that talk about Revit and text problems has been long discussed here and there is no much that we can do about it, nevertheless i want to share with this community some points about an Odd behavior I'm experiencing and which it seems don have a solution yet.
As already said I'm running Revit 2017.2 in win 10 Professional 64 BITS, Intel Core I7 - 7820 HK, CPU @ 2.90GHz CPU 2.90 GHz, 32 GB RAM DDR4 and a Nvidia GeForce GTX 1080.
So in theory all should work nice; but my Revit systematically crashes out when I'm in "Text edition mode" in a sheet, I mean I have a lot of sheets and some time I need to add some textual notes in some sheets but since I select any text the software closes the window and shows me an error message that just says that Revit needs to close, the odd thing is that Revit continues "Working" even with 0 sheets open, 0 views open, so I must use CTRL+ALT+SPR to close Revit and re open it.
The same thing happens when I open the view out of the sheet and try to edit the text, but when I do this is just the sheet that closes out, so I can continue to work.
Did any of you already experienced the same behavior? is there a solution for this since it seems that all the reports I've send to Autodesk doesn't have an answer yet, Thanks for your comments
