Question: How can I set the Material Render Appearance through the API?I can see there is the Autodesk.Revit.DB.Visual.Asset class, but how do I add to the list of Autodesk.Revit.DB.Visual.AssetProperty objects for a new material?Answer: The good news is that this is possible in Revit 2018.1 using the Visual Materials API.Check out Boris Shafiro's class at AU to learn about it...
