Is there a published reference for the Assembly Codes? I realize you can pick the appropriate one from the tree inside the type editor, but I am looking for the publication that defines them in order to understand the categories better.
Assembly Codes
If I recall correctly it is based off of the CSI48 master format found in the link below.
http://www.csinet.org/Home-Page-Cate...rs-Titles.aspx
Sorry, I get these mixed up all the time. It's based off Uniformat division codes.
http://www.fire.nist.gov/bfrlpubs/bu...PDF/b99080.pdf
Second page shows the same layout that the assembly codes follow.
Is it possible to add gridlines to an assembly (i believe not) or is there a way to make them visible in the assembly-views if there...July 14, 2011, 12:58 PM -
Hi all!
I tried to create an assembly within an assembly but I'm getting an error message the some of the elements are not allowed. Is there...January 28, 2016, 01:53 PM -
did anyone else experience problems with braces in an assembly?
When I create the assembly they are fine and when you...-
August 2, 2011, 10:50 AM -
Hello Everybody,
Consider I have a room with two tables, a bed, and a fridge. I made an assembly of all these objects inside the room and...March 19, 2015, 01:47 PM -
I cant find a straight answer anywhere what exactly this is? I keep seeing something about Uniformat but I also don't know what that is. I'm using revit...
Channel: MEP - General
June 4, 2014, 02:07 PM -
