We're using an open grid ceiling system in one of our projects, and when I try to render views where the ceiling is visible, the ceiling material appears to be duplicated and rotated.
I think what might be happening is the material on the face of the ceiling is rotating to match its surface (model) pattern, so it is registering correctly on the face of the ceiling, but the material of the upper surface is not rotating with it. Whats strange is that this doesn't appear when looking at the view in Revit with the graphic display is set to "Realistic". The material Appearance settings are just a color, and a cutout image inverted:
I'm at a loss for how to resolve this other than to literally create a vertical opening for each cell in the ceiling!
Thank you in advance for any thoughts/ideas/solutions!! (Apologies if this topic has been discussed before; I couldn't find any solution via searching)
