Does anyone know why this happens? This has been a frustration for quite a number of years now.
I have an existing stud wall with GB, and have new stud walls coming into each side of the existing wall. All walls have the same construction, same core and same finish materials. One wall coming into one side of the existing wall extends the core layer to the existing wall's core layer. That makes only a slight graphic discrepancy, which is imperceptible when Thin Lines are turned off, or on the printed output.
However another wall coming into the opposite side of the existing walls extends its core layer the same way, but then makes this huge white cutout in the existing wall all the way through to the opposite side. It appears to do that on the wall attaching to the Exterior side of the existing wall. The one with the minor discrepancy is on the Interior side of the existing wall. If I flip the existing wall, the join discrepancies reverse between the new walls. Why does this happen?
It's really frustrating and slows me down because then I have to go back after the fact and set the ends of the new walls to Disallow Join. And doing that a few hundred times gets real old real quick.
