columns are respresented by blue colour.
Joining 2 walls together overrides the column...
You're making us work rather hard to help you out. What exactly is the problem? After trimming the walls the column is inside the walls? This is default behaviour for architectural columns to join with walls. If you don't want this use structural columns.There are no stupid questions, only stupid people
Im trying, in plan view, to make the column more visible among two walls. At the moment it looks to be joined together as one piece, I want it to pop...July 15, 2016, 03:00 PM
We have some concrete piers/pilasters that, in plan, are joined with walls. This makes the piers look like jigsaw pieces in my GCS. My engineer does...
April 30, 2012, 12:36 PM -
Yesterday while trading messages with a friend we discussed my previous post about columns disappearing. He suspected it might explain the issue he was...
Channel: Blog Feeds
May 24, 2019, 01:15 AM -
One of our teams came across this issue the other day and I thought I would share.
Below are two pairs of concrete columns: Two are Columns...October 8, 2019, 09:20 PM -
A lot of the work we do is fairly generic retail and has brick wrapped columns along the canopy. I'm curious what the best way to create these is. I've...August 7, 2012, 10:01 PM
