Is it possible to have a view title with a north arrow included that can be rotated, either by angle or by check box? I have made the view title family itself and the North arrow rotation works fine within the family editor, saved as an angle shared parameter. Then I also added a project parameter linked to the same shared angle parameter and set to views. But when I load it into a viewport and change the rotation angle the north arrow no longer rotates. I added a square footage text label to the view title with the same process and that works fine, is there an additional step I missed to link the shared angle parameter or will this only work with labels?
An additional option would be to have a shared <family type> parameter to load 1 of 4 directional north arrows but if this process only works for labels then that wouldn't work either.
