All,
I have 2 models that need to, in essence, be merged.
One is Drains/Piping from a foundation plan that was initially intended be constructed as part of an initial project, but it has since been packaged with the rest of the project (which is the ground floor work and above, floors 2-X).
I need to combine the foundation work with the work above and will eventually need to make connections when I get to that stage.
Is this possible? Is there a clean way to insert the floor plan with annotation, etc. into the new model and line up on a common coordinate so everything will line up?
Thanks for any help/insight!
