DWG export to ACA : PI wrong
  • snowyweston
    Disconcerting that these jokers produce much of the software that many technical industries rely upon.
  • HansLammerts
    started a topic DWG export to ACA : PI wrong
    I noticed PI is used wrong in calculations using DWG export option => ACA.
    Maybe that is the reason that Autodesk doesn't like them to show by default :hide:
    This error could just as may caused under the hood of these AutoCAD verticals.
    However, it would be nice to have these programms work more or less the same.
    .. Just so you have seen it once..
