Annoying Error Message During Navis Export Interrupts Massive Export
    I started getting these error messages a couple months ago and it's pretty annoying...wondering if anyone has ever experienced it before.
    "XYZ - Printer cannot be used with ARCH E_36x48 print settings. The <in-session> print settings will be used."
    *close button*
    I have to click "close" and the export resumes. However, this error interrupts my navis export several times in one export session (over 6 times...once every 30 minutes or so). When I click through the final instance of this message, it takes two solid hours to crank out the model.
    The first time I encountered it I entered the export process and went to bed the evening before a big coordination session. Then when I awoke, I found these messages and thought I was stuck in a nightmare. It was bad.
    I haven't seen it, but what happens if you set a different printer before exporting?
    chad
