We are working on a decent sized project, and have linked in the Architects model. Our model is a central file within our network (just in case that makes a difference), and the model they gave us is a central file within their network. The bigger the project gets, the slower the software moves. Is there any way to pare their model back to only what we need to work with, i.e. manipulate their worksets etc... Thanks ahead of time.
Linked model is slowing down software
If you create the same Worksets that are within their model then you can speed things up by then turning them off. Find the content you don't need to work with, or only need to see in certain situations & create those corresponding Worksets. Same named Worksets can talk to each other from linked files. Another solution is also incorporating Categories of course. All these settings can be easier to deal with when utilizing View Templates for working purposes too.
Maybe removing all of their CAD/Revit Links can help too.
Have you done a SaveAs on their model and made a new Central on your server?
If all you did was copy their file to your server and Link it, it still looks for Central File info on their server and can waste a lot of time figuring out that the Central model can't be found.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by cftrevizo View PostIf you create the same Worksets that are within their model then you can speed things up by then turning them off. Find the content you don't need to work with, or only need to see in certain situations & create those corresponding Worksets. Same named Worksets can talk to each other from linked files. Another solution is also incorporating Categories of course. All these settings can be easier to deal with when utilizing View Templates for working purposes too.
On Monday I am due to upload our model onto a file sharing website.
This will be the first time we have shared a model so I have a few questions....September 6, 2013, 03:09 PM -
Okay, this is the ken-under-arm (yuk, stale plastic...)
I have a Structural Model (RST), Steel Fabrication model (RST from Tekla via IFC),...April 29, 2012, 08:49 PM -
Received a model from designer. Made it the central model on our internal server. Internal team working on local files using a new workset within model....
Channel: Worksharing and Cloud Coordination
October 2, 2019, 09:02 PM -
Working on project that I have a consultant who during schematic design needs access to my architectural model to make changes/updates. Would like each...October 29, 2014, 12:50 PM
We (a UK based practice) have come to the end of our role with a local firm on a job out in Australia - but given "the times" and some spare...
March 31, 2011, 02:14 PM -
