Foundation plan - Hidden lines/ Edge lines
    I have an issue with my foundation plan. I don’t understand why there are a line between two elements (isolated foundation and a beam) with the same thickness. I could use the linework tool but I don’t find it effective in this case.
    Thank you very much.
    Are both elements the exact same material?
    Tony Perez @Twitter
    Senior BIM Specialist
    Salas O'Brien
      Hi Tony,
      Both elements are <by category>. I set both elements to the same material in the Object Styles Manager and…voilà. That works.
      However, this does not seem to work retroactively. All the elements that have already been modeled are shown as before.
        The material parameter for structural framing (beam) elements is an instance property, therefore you'll first have to "select all", and then change the material.
        Tony Perez @Twitter
        Salas O'Brien
