After watching tutorial on this I was able to make my window to slope with the roof, but can't make it cut the wall for the part I reshaped.
How to make sloped window cut the wall?
Looks like you forgot to change the opening (or void) in your window family.Company Website: www.deurloobm.nl
Originally posted by Robin Deurloo View PostLooks like you forgot to change the opening (or void) in your window family.
Yeah... I got it to work after discovering the void was initially created on the side view. Deleted it and created a new opening in the front view.
Can I put a parameter( height or angle) that allows me to change the upper part to match with my roof in case roof pitch is changed or simply to make it more flexible for future use? Eh actually learning and still have to dig more and more.
Thanks again.
No problem, we have all been there.
You can add a parameter to your window to control the height of the top corner or the angle of the sides. just need some ref lines and dimensions. Made a quick example. It is in Revit 2018.
Oh and forgot to say "Welcome to the forum", so Welcome to the forum !Attached FilesLast edited by Robin Deurloo; October 26, 2017, 10:50 PM.Company Website: www.deurloobm.nl
sure, here you go!Attached FilesCompany Website: www.deurloobm.nl
No problem, let us know if you get it to work in your project.Company Website: www.deurloobm.nl
Originally posted by Robin Deurloo View PostNo problem, let us know if you get it to work in your project.
Thanks for the help again.
There is a parameter in the family called angle, you can change that (set it to the same angle as your roof) and the opening changes according to that angle.Company Website: www.deurloobm.nl
Hello
Right now I have a couple of doubts and I dont know how to proceed.
I was hoping soemone could help me out.
1. First I need...March 30, 2011, 08:14 PM -
Hello there
How do I start building a skylight window or window in a roof like a velux window, but a circular one. I cannot find a circular...-
January 29, 2014, 10:51 AM -
Is it possible to create a window between roof and wall, so I could just paste the window without any additional cutting and profile editing?
October 16, 2014, 02:44 PM -
I'm trying to make this roof window as attached.
My problem is that I simply can't get a void to cut the roof and the floor underneath. I've...-
April 10, 2013, 12:46 PM -
Hi, i have this tilted window it is ok in width but with height it is not working can anyone help me on this ?...
January 7, 2012, 03:17 PM -
