I have a ton of sheets with various pour areas of different shapes and sizes, which in turn vary from floor to floor.
Every time I print a sleeve drawing, I have to make sure I check the appropriate box for the pour zone. These are shared parameters I've made and associated with individual filled regions (grey) inside the sheet family.
I'd prefer just selecting the sheet on the project browser and having a button show up on the properties palette that takes me to a dialogue box which allows me to check which pour area applies to that sheet. Sort of like how the revision column works. Except in this case, the selection I make controls a shared yes/no parameter within the title block sheet, which is associated with a grey filled region.
Even better would be to open up my drawing list (a schedule) and having the pour zone show up as a drop down box from which I can select the zone ID (or possibly just type in the exact alpha-numeric pour zone ID). I don't think this is possible, but I was hoping to pull the drawing list to excel, manually type in the exact pour zone ID, and push that back into Revit so it updates all those sheets with a shaded box on the key plan showing where on the floor plate you're looking at.
Anyways, this might be something for dynamo...unfortunately I haven't learned that yet.
Hope to hear any good ideas.
Thanks!
Thanks!
