Hi Guys, I have stairs going from level 0 to level 3, and on level three only half of the stair should be visible but when i draw the stair and look into plan view the part of the stair that should not be present on level three is there. On 3d view everything is ok. What is the problem? I tried bt could not find a solution. Thanks for your answers.
Stairs Problems
Looks like that is the intended way stairs work. They do need a big overhaul if you ask me.
Seems there are just tricks and workarounds.
https://www.revitforum.org/architect...iew-depth.html
https://forums.autodesk.com/t5/revit...e/td-p/3405241Company Website: www.deurloobm.nl
This is the problem we are experiencing. 3 story building. The stair from level 1 too level 2 shows on the level 2 plan. A portion of the stair that goes...January 11, 2011, 06:33 PM
I'm working on a three story building with several stairs in it. In the interest of improving on the last building I did where the stairs were a complete...January 8, 2013, 06:35 PM
I am trying to create stairs by sketching, the problem is, that they are switchback stairs, that extend two stories. Because of this, naturally, the boundaries...April 2, 2019, 03:39 AM
Firstly, a few general matters.
Given the change in the stairs with stairs by components etc, one needs to use the new templates which...March 27, 2012, 10:09 PM -
Hey,
I have 3 one-story stair. Bt i want to numbring them as multi-storey.
I mean, i want from 1 to 63. But it always starting...June 8, 2017, 12:33 PM
