Connectors in array - is it possible?
    Hello,
    I have just created a family - pipe collector. I can easly modify amount of connections by typing the number. It changes the length of the whole collector and number of connections. But I have a problem to actually set the pipe connectors. Revit refuses to put connectors into the array. So my family is uselss because i cant actually connect it to pipes. It is just an empty block. I can set them manually to every type of collector but thats not a point. What if i have collector with 20 connections? Do I have to build it manually?
    Any idea how to create such a families with multiple connectors?
    Regards
    This does work if you first set your array to the max number of connections you expect, then place a connector on every pipe extrusion.
    Then if you reduce the number of connections in the array, the extra connectors should disapear with the extrusions.
      Thanks! That is good enough for me
