Revit OpEd: Quick Tip - Move a View to a New Sheet
  • Revit OpEd
    started a topic Revit OpEd: Quick Tip - Move a View to a New Sheet
    If you realize that you've put a view on the wrong sheet you can just select it and "delete" it. The view is removed from the sheet, no it isn't actually deleted (on the off chance you haven't done it before now). Probably already knew that much. Did you know that you can drag and drop it on another sheet instead? When you expand a sheet listing so you can see the views that are on it, listed under the sheet name, you can select a view and drag it to a new sheet. When you let go of the mouse button (ends the drag mode) Revit will open that sheet and let you place it.
    Yet another way to manipulate stuff. In practice it becomes harder to use when you have a real project with lots of sheets. Often you can't get both sheets within your view of the browser and it's a little awkward to scroll up the Browser. Revit will do it, just have move your cursor toward the top or bottom of the frame to convince it you want to.
